SomebodyInGNV
Aug 20, 2022Guide
RBR20 Orbi guest network doesn't allow special characters?
I'm on firmware V2.7.4.24. I'm using WPA2-PSK security for the wireless network and have been using a password with special characters since I first set it up. I just tried to enable the guest netwo...
CrimpOn
Aug 22, 2022Guru - Experienced User
SomebodyInGNV wrote:
My main network password contains spaces and a hyphen.
Very puzzling. I have now changed the Guest WiFi password to:
- Phantom-? (hyphen and ?)
- Phantom ? (space and ?)
Both "take" and a tablet can connect to the Guest WiFi network using the current password.
My conclusion is thus that in the case of my Orbi, Netgear has not forbidden "special characters" in the Guest network password.
I could continue experimenting with more spaces, more hyphens, space at the beginning or end, etc. etc. Since it is unlikely that I will stumble across your guest WiFi, would you mind providing the exact password so that I can test it on my Orbi?
ekhalil
Aug 22, 2022Master
Can the problem be with the name of the guest network (the Guest SSID)?
- SomebodyInGNVAug 22, 2022GuideI don't think so. The error message clearly refers to the format of the password.
The only thing I think I can get here is for someone to confirm or refute my experience. Do you use a complex password on a guest network?- CrimpOnAug 22, 2022Guru - Experienced User
I have used a password with space and "?" and a password with hyphen and "?".
Will be happy to type your exact password into my Guest WiFi password field.
(I know we tell people, do not share personal information on the forum. But, c'mon. What am I going to do? Drive around America (Europe?) entering this string into every WiFi network that I come across???... and hope that you did not change even a single character???)
It's a hyphenated personal name so I'd rather not post it publicly.
Try "Ingrid Nancy Foster-Smith"
