SomebodyInGNV
Aug 20, 2022Guide
RBR20 Orbi guest network doesn't allow special characters?
I'm on firmware V2.7.4.24. I'm using WPA2-PSK security for the wireless network and have been using a password with special characters since I first set it up. I just tried to enable the guest netwo...
ekhalil
Aug 22, 2022Master
Can the problem be with the name of the guest network (the Guest SSID)?
SomebodyInGNV
Aug 22, 2022Guide
I don't think so. The error message clearly refers to the format of the password.
The only thing I think I can get here is for someone to confirm or refute my experience. Do you use a complex password on a guest network?
