Stevevoisey
Jun 25, 2020Initiate
RBR20: periodic internet outages
We bought a 2-pack (RBR20 + RBS20) 2 months ago. Our connection speed is now exceptional connected to the fibre router. We really like the product. We moved to a new house four weeks ago and bought a...
Jun 25, 2020Guru - Experienced User
I
