lentoc
May 19, 2020Aspirant
RBR20 (RBK23) - constantly rebooting itself
So my orbi system - 1 router, two satellites, worked like a dream for about 6 months. About a week ago I lose all my connections over 10-15x a day. FW version has been upgraded to V2.5.1.16 on a...
lentoc
May 20, 2020Aspirant
Charter/Spectrum is the ISP
Modem = Hitron technologies E31N2V1
I have had two new modems since this started accompanied with two IP address changes. The problems return almost immediately and thus I don’t think I’m truly under a ddos attack or anything like that. Lot of the message board reading leads me to believe false positives.
Who is returns always to Facebook.
Live in a populated suburb so lots of WiFi around.
Haven’t tried system without both satellites turned on. Hasn’t been suggested by netgear support either. I can try that today.
Uploaded file is the whois info on that ip. But let’s be clear there are many ips and logs that show the same info. All that I checked lead back to Facebook.
May 20, 2020Guru - Experienced User
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
- lentocMay 20, 2020Aspirant
So i set the radios to 50% a few hours ago and it continues to reboot.
Will try the satellite removal here shortly and see if that makes a difference.
Does netgear do rma up to one year.? This is getting crazy.
Ok so radios ar half power now and one satellite removed from mix. Uptime is 17 minutes now so we will see how long it lasts. Here is fresh router log...
admin login] from source 192.168.1.12, Wednesday, May 20, 2020 20:34:23
[DoS Attack: RST Scan] from source: 34.98.102.181, port 1883, Wednesday, May 20, 2020 20:32:09
[DoS Attack: ACK Scan] from source: 3.132.204.55, port 443, Wednesday, May 20, 2020 20:31:38
[DoS Attack: SYN/ACK Scan] from source: 185.209.179.76, port 25461, Wednesday, May 20, 2020 20:29:54
[DoS Attack: ACK Scan] from source: 3.132.204.55, port 443, Wednesday, May 20, 2020 20:28:38
[DoS Attack: SYN/ACK Scan] from source: 185.209.176.22, port 25461, Wednesday, May 20, 2020 20:25:51
[DoS Attack: ACK Scan] from source: 3.132.204.55, port 443, Wednesday, May 20, 2020 20:25:38
[DHCP IP: 192.168.1.12] to MAC address d0:4f:7e:5d:2d:1a, Wednesday, May 20, 2020 20:25:08
[DHCP IP: 192.168.1.6] to MAC address 4c:17:44:c0:1e:c8, Wednesday, May 20, 2020 20:23:22
[DoS Attack: ACK Scan] from source: 17.248.132.54, port 443, Wednesday, May 20, 2020 20:23:15- lentocMay 20, 2020Aspirant
Symptoms still present with and without satellites.
