Verilogger
Aug 21, 2019Aspirant
RBR20 Restarts randomly
I have a RBR20 set up in router mode. Two RBW30 Satellites FW: v2.3.5.26 Satellite FW: v2.3.5.6 Guest network is off Arris TM1602 cable modem 3000 sq ft house I have performed factory reset of the rou...
Aug 21, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
