Verilogger
Aug 21, 2019Aspirant
RBR20 Restarts randomly
I have a RBR20 set up in router mode. Two RBW30 Satellites FW: v2.3.5.26 Satellite FW: v2.3.5.6 Guest network is off Arris TM1602 cable modem 3000 sq ft house I have performed factory reset of the rou...
Aug 21, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Verilogger
Satellites are less than 30' apart.
I have tried these suggestions in the past and it did not work.
- FURRYe38Aug 21, 2019Guru - Experienced User
The satellites need to be 30 feet or more.
What happens if you turn OFF the RBWs and just leave the RBR running...still happens?- VeriloggerAug 21, 2019Aspirant
All of the satellites were working well until the firmware upgrade. I removed one satellite to see if this makes any difference. The router re-initializes 5 - 20 times a day and I am not sure, but it seems to happen when the entire family is trying to work at the same time.
I suppose you might try downgrading FW and see if this helps. IF not, I recommend you contact NG support and get more help on the RBR. Possible the RBR is faulty and needs to be replaced.
