Verilogger
Aug 21, 2019Aspirant
RBR20 Restarts randomly
I have a RBR20 set up in router mode. Two RBW30 Satellites FW: v2.3.5.26 Satellite FW: v2.3.5.6 Guest network is off Arris TM1602 cable modem 3000 sq ft house I have performed factory reset of the rou...
Verilogger
Satellites are less than 30' apart.
I have tried these suggestions in the past and it did not work.
Aug 21, 2019Guru - Experienced User
The satellites need to be 30 feet or more.
What happens if you turn OFF the RBWs and just leave the RBR running...still happens?
- VeriloggerAug 21, 2019Aspirant
All of the satellites were working well until the firmware upgrade. I removed one satellite to see if this makes any difference. The router re-initializes 5 - 20 times a day and I am not sure, but it seems to happen when the entire family is trying to work at the same time.
- FURRYe38Aug 21, 2019Guru - Experienced User
I suppose you might try downgrading FW and see if this helps. IF not, I recommend you contact NG support and get more help on the RBR. Possible the RBR is faulty and needs to be replaced.
- NpkelleyOct 18, 2019AspirantI’m Having this exact same problem. Did you get it fixed? If so how?
