Verilogger
Aug 22, 2019Aspirant
RBR20 Restarts randomly
I have a RBR20 set up in router mode. Two RBW30 Satellites FW: v2.3.5.26 Satellite FW: v2.3.5.6 Guest network is off Arris TM1602 cable modem 3000 sq ft house I have performed factory reset of the rou...
Npkelley
Oct 18, 2019Aspirant
I’m Having this exact same problem. Did you get it fixed? If so how?
Oct 18, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- NpkelleyOct 18, 2019AspirantI have now tried all of these things. I also have been trying this without the satellites, just he router. Still random reboots. I’m going to drop down in the firmware and see if that helps.
- JC1138Dec 18, 2019Aspirant
I am seeing the same symptoms after upgrading from firmware V2.3.1.58 to V2.3.5.26.
This is an RBR20 supporting two RBS20s.
Previously I had no issues with this configuration rebooting but after the update it is happening consistantly. About once an hour.
Other posts suggested a power stability issue which I question. I am running the router on a UPS backed powersource and see no issue with the power.
I will try to regress to the older firmware to see if it stablizes. How did you're firmware regression work?
update -
Attempting to revert the firmware, the RBR20 rebooted part way through the process so is now bricked.
Opeing a case with support for next steps. If you're experiencing this issue, be careful in trying to regress the firmware!
