bjbutchart
Aug 30, 2020Aspirant
RBR20 Router has no WiFi signal
Hi, The router is not generating a WiFi signal and cannot be accessed using the orbi app and reads as offline. We have active internet access via NBN and our old optus wifi router. Process followe...
Mstrbig
Aug 30, 2020Master
Were you ever able to get to configure the Orbi router through the app?
bjbutchart
Hey,
I had used the app to access the router a number of times. Infact the last action I took with the router was via the app where I turned off internet access to a device on the network.
Thanks for the reply.
