Rcot
Jun 25, 2021Aspirant
RBR20 router won’t allow access to outgoing Earthlink email server
Equipment: RBR20 router with 2 satellites. ISP: Spectrum Devices used: two Dell laptops, two ipads, two iPhone 12. All connect via WiFi. Email apps used are both Outlook and the built-in iOS mail ...
Jun 25, 2021Guru - Experienced User
since you're using an email program, does it work if you're sending from an online hosted program?
Have you tried a different dns? like googles at 8.8.8.8 or 8.8.4.4 or even cloudfare at 1.1.1.1
- RcotJun 25, 2021AspirantIf I understand your question, if I log into the Earthlink web mail service, all is well. Also, if I use iCloud mail, it works. Only Earthlink fails.
