Rcot
Jun 25, 2021Aspirant
RBR20 router won’t allow access to outgoing Earthlink email server
Equipment: RBR20 router with 2 satellites. ISP: Spectrum Devices used: two Dell laptops, two ipads, two iPhone 12. All connect via WiFi. Email apps used are both Outlook and the built-in iOS mail ...
CrimpOn
Jun 25, 2021Guru - Experienced User
Can anyone shed any light on cause or fix? My next move would be to nuke the Orbi and set it up again from scratch. Thanks for any help.
plemanssuggested experimenting with using a different DNS server setting on the Orbi. (on the Orbi web interface, Internet page).
Another experiment would be to open a DOS window on one of the Dell laptops and do a nslookup for smtpauth.earthlink.net
My computer returns this:
Non-authoritative answer:
Address: 51.81.61.14
Address: 51.81.61.13
Address: 51.81.229.172
Address: 51.81.229.171
Are Armor or Parental Controls enabled on this Orbi?
