Timnooner
Mar 30, 2024Follower
RBR20 Satelite
Looking to connect an ethernet cable (cat5e) between my Orbi Router and satellite. Cable tested good. No hand shake between the 2. Do I have to make a crossover cable or something? TIA
Apr 01, 2024Guru - Experienced User
try a different cable. it wouldn't be the first one that "tested good" on a cable tester but wasn't of high enough quality ends/cable to actually pass a signal.
