nmklong
Jun 24, 2020Tutor
RBR20 satellite acting up after firmware upgrade to 2.5.1.16
So i saw a new firmware update and decided to update to 2.5.1.16 a few days ago. After the update, i notice i have troubles with the wifi pretty often. I tested internet speed directly from the r...
Jun 24, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Has a factory reset and setup from scratch been performed since last FW update? Something to try if you haven't already.
