Lmntry
Jul 06, 2018Follower
RBR20 Satellite and printer
I just bought the RBR20 system from Costco. I put the Satellite at the opposite end of my home to support two older Canon printers. Neither of the printers will connect via WiFi to the Satellite, but...
JazWilliams
Jul 10, 2018Aspirant
I was having the same problem, and found a fix without needing an Ethernet cable. On your printer go into LAN settings, find Other Settings, and then go into TCP/IP settings and change it to IPv6.
Edit: I just reread your problem. When I connected my printer to the network, I chose the manual setup. It detected that there was more than one connection available, and there was an option to use all or one. I chose all, and put in the password. Maybe that will work.
