oppnhmr
Jun 24, 2021Aspirant
RBR20 satellite problems
I have an RBR20 router and a satellite RBW30 which worked great for the first year or so but suddenly the satellite stopped working. I've used the Orbi app multiple times and the light on the top of...
Jun 25, 2021Guru - Experienced User
Can you use a wired PC and web browser and log into the RBRs web page to see if the RBW is connected there and if so does it have an IP address? You can do this with the RBW plugged in somewhere near the RBR or even in the same room as the RBR.
What Firmware version is currently loadedon the RBR?
Has it been updated receently?
oppnhmr
Jun 25, 2021Aspirant
Thanks I will try this. As I mentioned in the post, it wouldn't update the firmware. No idea why. It just says "failed" each time i've tried.
- FURRYe38Jul 02, 2021Guru - Experienced User
Be sure your unpacking the .zip file to reveal the actual FW file.
Try a different browser, IE11, Edge or Firefox.
Checking the RBRs web page under connected devices will show you the RBWs connection and IP address. You can use this IP address for the RBW to log into and send the FW file direct to the RBS.
Please don't yell.
