pkbhas
Jul 23, 2020Aspirant
RBR20 Satellite when enbled causes intermittent internet
when the satellite of RBR20 is switched on, there will be frequent disruption of interrupt connection. When its left switched off, and have only the main router, then there will be no intermittednt...
pkbhas
Jul 24, 2020Aspirant
Firmware Version: V2.5.1.16
AP mode is ON.
modem model:E31T2V1
Size of home: 3000 sqft
Distance between router:
Main rounter in 1st floor.
Satelite in 2nd floor at a vertical height of 10 ft and horizontal diatance of apx: 15-18 ft.
Jul 25, 2020Guru - Experienced User
Your modem model doesn't have a built in router or wifi. IF you have your Orbi in AP Mode, this needs to be changed to router mode as there needs to be a router in between the modem and your wifi devices.
- pkbhasJul 25, 2020Aspirant
The router mode is set. My apologoes for not checking it throroughly
