Jschnorr
Apr 18, 2020Aspirant
RBR20 Satellite working or not
Hi, i recently added another Orbi RBR20 to my Orbi network. It didn't work the first time so I had to try it several times. At the end it looks liked it worked. However, I am not sure. The new Orbi...
ekhalil
Apr 19, 2020Master
If you added a router to an existing Orbi network you should see the new router as a separate system in the Orbi app under “Your Products”.
