KSSmith1022
Mar 20, 2023Follower
RBR20 Security Key
Security key location
KevinLiT
Mar 22, 2023NETGEAR Moderator
Hell KSSmith1022,
Welcome to the NETGEAR Community!
I understand that you would like to know the location of your RBR20 security key. If you are the administrator of your Orbi system you can change this key from your Orbi app.
To change the security key using the app please follow the steps below:
- Tap WiFi Settings.
- Type your new SSID in the WiFi Network Name (SSID) field.
- Type your new password in the Network Key (Password) field.
- Tap SAVE.
Best,
Kevin
Community Team
