brissle20
Dec 08, 2020Aspirant
RBR20 set-up problems
Hello everyone, P{lease can someone help / advise me?
We are older people, not very computer expert so much of the language used by professionals is not understandable by us.
We habe rubbish WiFi at home and after reading several articles decided that an Orbi Mesh system should make things better.
We have a PC plugged direct in to the router supplied by Virgin media (has been updated a year ago) and that is suppoosed to provide WiFi throughout the house. But we have thick, soldid stone walls and many rooms have no signal. So our laptop and tablet and mobile phone struggle to work outside the office area.
So we bought the Orbi RBR 20 and did our best to fopllow the instructions on the app which we downloaded.
We have set up the orbi router, plugged in to the Virgin media router and have placed both sattellites in suitable places. Bur when we try to start the set up by linking the phone (an Apple iPhone 5) we keep getting the message "Orbi Not Found". We Googled the problem and have tried re-starting the main router and the Orbi router, but nothing changes. The lights are out on the sattellites, but the main Orbi router is still glowing.
There's a sort-of signal downstairs, but the Hudl tablet won;t connect.
Is it all supposed to be one same WiFi network everywhere? Why can't we make the connection?
Would be very grateful for answers that amateurs can understand!
Thanks
brissle20 wrote:Hello everyone, P{lease can someone help / advise me?
We have a PC plugged direct in to the router supplied by Virgin media (has been updated a year ago) and that is suppoosed to provide WiFi throughout the house. But we have thick, solid stone walls and many rooms have no signal. So our laptop and tablet and mobile phone struggle to work outside the office area.
This is really awkward. There are two separate issues (a) setting up the router using the Orbi "app", and (b) getting satellites to function.
a. Setup
(Confession: I do not use the "app" to set up Orbi WiFi. Being "even older", I am only comfortable with using a web browser connected directly to the Orbi router.) When the Orbi is first turned on, it is supposed to broadcast a WiFi signal with the credentials printed on the product label (on the bottom of the router - and sometimes on a plastic sleeve around the router which people immediately throw away). It is almost always "ORBI" plus two digits. The iPhone needs to connect to this WiFi signal in order to search for the Orbi. Of course, the Orbi WAN port will have to be connected to the Virgin media hub (and once the Orbi is working, the PC should be unplugged from Virgin media hub and plugged into the Orbi.)
b. Satellites
This is the awkward part. Orbi is designed for the satellites to communicate with the router over a WiFi signal. If the stone walls block the existing Virgin media WiFi from reaching other rooms, they will almost certainly interfere with the Orbi router-satellite connection. The procedure is this: Plug in a satellite (temporarily) in the same room as the router. Power it on and "Add it." Once added, the satellite should glow blue at the top (called the "ring light") for up to two minutes and then have no light.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
After the satellite is working, move it to the desired location and turn it on again. If the ring light turns blue, service will be great. If it turns amber, the connection is poor. If it turns magenta, the connection is too poor to function.
- brissle20Aspirant
I discovered this reply in my junk mail this evening.
Will look at it again tomorrow and respond.
Thank you so much for the suggestions.
"Junk Mail" pretty much sums up my life right now. (sigh)
I really hate to be discouraging. Stone and concrete are horrible impediments to WiFi. This type of wall makes installing ethernet cables for backhaul impractical unless you really enjoy drilling holes.. What many people have done is use PowerLine adapters with the existing electrical wiring to connect the satellites to the router. Alas, many older buildings also have "older wiring" which sometimes is not suitable for PowerLine.
