colinson
Mar 13, 2020Tutor
RBR20 Slow Wifi
This post is nothing new, plenty of similiar ones on the board. I've got 500/50 cable to curb. It's an Arris modem, DG3450A. I've got an RBR20 and three satelites. One is daisy chained. They'...
Mar 13, 2020Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Power OFF RBR and RBS for 1 minute then back on?
I would factory reset and setup from scratch at some point...
- Retired_MemberMar 13, 2020
FURRYe38 wrote:What Firmware version is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerTry setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Power OFF RBR and RBS for 1 minute then back on?
:smileymad:
- colinsonMar 14, 2020Tutor
Yeah that cut and paste reply in every post of this ilk not much help here.
- Retired_MemberMar 14, 2020
colinson wrote:Yeah that cut and paste reply in every post of this ilk not much help here.
Agree....it's used by those who try and answer ALL the posts without reading and understanding the problem while taking the time to actually typing a response. Not to mention the responses that are really no more than guesses in disguise.
Yeah, I've seen that cut and pasted advice and questions before.
Most of those are answered in teh post. But I did also try turning off Fast Roaming 20mhz/40mhz coexistence.
- colinsonMar 28, 2020Tutor
I'll refrain from making generic comments about Orbi (although def making them under my breath) but Orbi really didn't work for me.
Reset and went through set up again without much improvement in performance.
So I bought an eero pro and two Beacons. And out of the box man, wired 800mbs compared to 400 for the Orbi and wifi coverage of 200 - 300 throughout the house compared to 15 or less for the Orbi.
I don't know what the difference is but for my home and circumstances eero >>>>>>> Orbi.
Anyway, if anyone wants an RBR20 and three satellites, just shipping. Send me a message
