colinson
Mar 13, 2020Tutor
RBR20 Slow Wifi
This post is nothing new, plenty of similiar ones on the board. I've got 500/50 cable to curb. It's an Arris modem, DG3450A. I've got an RBR20 and three satelites. One is daisy chained. They'...
Mar 13, 2020Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Power OFF RBR and RBS for 1 minute then back on?
I would factory reset and setup from scratch at some point...
Retired_Member
Mar 13, 2020
FURRYe38 wrote:What Firmware version is currently loaded?
:smileymad:
- colinsonMar 14, 2020Tutor
Yeah that cut and paste reply in every post of this ilk not much help here.
- Retired_MemberMar 14, 2020
colinson wrote:Yeah that cut and paste reply in every post of this ilk not much help here.
Agree....it's used by those who try and answer ALL the posts without reading and understanding the problem while taking the time to actually typing a response. Not to mention the responses that are really no more than guesses in disguise.
