colinson
Mar 13, 2020Tutor
RBR20 Slow Wifi
This post is nothing new, plenty of similiar ones on the board. I've got 500/50 cable to curb. It's an Arris modem, DG3450A. I've got an RBR20 and three satelites. One is daisy chained. They'...
Mar 13, 2020Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Power OFF RBR and RBS for 1 minute then back on?
I would factory reset and setup from scratch at some point...
colinson
Mar 14, 2020Tutor
Yeah, I've seen that cut and pasted advice and questions before.
Most of those are answered in teh post. But I did also try turning off Fast Roaming 20mhz/40mhz coexistence.
