colinson
Mar 13, 2020Tutor
RBR20 Slow Wifi
This post is nothing new, plenty of similiar ones on the board. I've got 500/50 cable to curb. It's an Arris modem, DG3450A. I've got an RBR20 and three satelites. One is daisy chained. They'...
Mar 13, 2020Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Power OFF RBR and RBS for 1 minute then back on?
I would factory reset and setup from scratch at some point...
colinson
Mar 28, 2020Tutor
I'll refrain from making generic comments about Orbi (although def making them under my breath) but Orbi really didn't work for me.
Reset and went through set up again without much improvement in performance.
So I bought an eero pro and two Beacons. And out of the box man, wired 800mbs compared to 400 for the Orbi and wifi coverage of 200 - 300 throughout the house compared to 15 or less for the Orbi.
I don't know what the difference is but for my home and circumstances eero >>>>>>> Orbi.
Anyway, if anyone wants an RBR20 and three satellites, just shipping. Send me a message
