Mannyk74
Jul 04, 2023Aspirant
RBR20 some IoT devices do not work anymore.
Hi there, I have 5 or 6 Tuya devices that I have flashed with Tasmota. They are from different manufacturers. Suddenly, a few days ago, I stopped being able to control them. I can find them on the n...
Jul 04, 2023Guru - Experienced User
Sonmething to contact the Mfr of these IoT devices about.
- Mannyk74Jul 04, 2023Aspirant
Thanks for your response.
Turns out it was a problem with my homebridge server. It just needed restarting.
- FURRYe38Jul 04, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
