DLars's avatar
DLars
RBR20 speed issue
When I run a speed test wired to my modem, I get around 850 mbps per second upload and down. Over WiFi and wired directly to the port on my RBR20 I'm only getting 85-90 mbps. Any ideas?
    Can you give more details?
    What make and model modem are you referring to? How is your RBR20 hooked up tp your modem, directly or via switch?
  • FURRYe38's avatar
    I
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M9702
    • DLars's avatar
      DLars
      v2.3.5.30 firmware.
      Dasan Zone Solutions. Can't find a model number. Attached to a fiber tray.
      • FURRYe38's avatar
        You might update FW to v16 since thats more recent. Factory reset and setup from scratch after loading it.
        I would power OFF the modem/ONT for 1 minute as well during the reset of the RBR and then back ON.
        Do you know if the ONT has a built in router and wifi or not?
        DLars wrote:
        v2.3.5.30 firmware.
