DLars
Aug 19, 2020Aspirant
RBR20 speed issue
When I run a speed test wired to my modem, I get around 850 mbps per second upload and down. Over WiFi and wired directly to the port on my RBR20 I'm only getting 85-90 mbps. Any ideas?
Aug 19, 2020Guru - Experienced User
I
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M9702
DLars
Aug 20, 2020Aspirant
v2.3.5.30 firmware.
Dasan Zone Solutions. Can't find a model number. Attached to a fiber tray.
- FURRYe38Aug 20, 2020Guru - Experienced User
You might update FW to v16 since thats more recent. Factory reset and setup from scratch after loading it.
I would power OFF the modem/ONT for 1 minute as well during the reset of the RBR and then back ON.
Do you know if the ONT has a built in router and wifi or not?
DLars wrote:
v2.3.5.30 firmware.
