RobGroen
Feb 02, 2021Aspirant
RBR20 SSID not visible on older Windows 10 laptop
Router Information Hardware Version: RBR20 Firmware Version: V2.5.1.16 GUI Language Version: V1.0.0.375 Operation Mode: AP I am unable to see the SSID from my private and gueat network on a o...
RobGroen
I tried connecting tot the Hidden network. That didn.t work. Can't connect is the message.
CrimpOn
Feb 02, 2021Guru - Experienced User
RobGroen wrote:I tried connecting tot the Hidden network. That didn.t work. Can't connect is the message.
Well, fudge. On my Windows 10 laptop, connect to hidden network brings up a box to enter the SSID.
After that, it brings up a box to enter the password. (I discovered that the SSID is apparently "case sensitive". It's a mystery to me why some parts of internet addresses are sensitive to UPPER/lower case and other parts are not.)
For sure, this laptop has only a 2.4G WiFi adapter, so 5G settings are not relevant.
- RobGroenFeb 04, 2021Aspirant
Hi CrimpOn,
Thanks for your sugestion.
I am a ICT-manager and Linux specialist. I know how to connect to a hidden network. As I mentioned in an earlier post I can't connect to the SSID with the "hidden network methode". It look like that the wifi adapter isn't able to communicate with the Orbi mesh network. It looks like they are both talking a other language.
- CrimpOnFeb 04, 2021Guru - Experienced User
Sorry if I missed this, but...
Is there some other WiFi that the laptop does connect to?
(an older WiFi access point? a smartphone Hot Spot?)
- RobGroenFeb 05, 2021Aspirant
SOLVED
I finaly managed to solve this issue by manualy installing a ar9485 driver from a Microsoft .cab file.
- Download this cab file:http://download.windowsupdate.com/d/msdownload/update/driver/drvs/2016/12/200036119_9051a7da45dcac7e6e91ce784802a5e4d5c021aa.cab
- Extract the file (it contains 3 files)
- Go into device management and find your WiFi card.
- Click right -> update driver
There is no suitable driver available on the Asus website, neither on the Qualcomm Atheros website and not in de default Windows update program.
