vt15
Jan 21, 2024Aspirant
RBR20 started having issues
My RBR20 was working fine and just all of a sudden it dropped off the network and would flash white. Config was one satellite, and the RBR20 was providing wifi access and one cable to a Docking sta...
michaelkenward
Jan 22, 2024Guru - Experienced User
vt15 wrote:
My RBR20 was working fine and just all of a sudden it dropped off the network and would flash white. Config was one satellite, and the RBR20 was providing wifi access and one cable to a Docking station which served any one 3 machines.
Usual boilerplate questions.
What firmware version do you have on the device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Did you reboot the network as recommended?
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
vt15
Jan 22, 2024Aspirant
Please find all answers below.
2.7.4.24. App or web Gui have not pulled anything down in 3 years.
It is the modem given to me by Spectrum. It has 2 Voice ports at the back, a Cable port and one ethernet port. It is TCH P/N: CVA4001CHR-R.
Yes, this has been done. I am currently stable for about 1 day but my RBR20 is not physically cabled to my docking station and I am using only wifi.
No messages in log.
Many thanks in advance.
