Freddie18
Aug 16, 2022Aspirant
RBR20 system with streaming problem on Vodafone NZ
Dear mates, I newly switched to Vodafone NZ. There is a problem that the streaming of MS Teams, Zoom, Youtube or Nintendo Switch gaming. The streaming will stop, freeze, lost voice channel for abo...
- Aug 17, 2022
Hello Freddie18,
Welcome to the NETGEAR Community!
I understand that you are having network stability issues with your RBR20 on Firmware version 2.7.3.22.
Please manually update your RBR20 to the current Firmware version 2.7.4.24 then check to see if the problem persists.
Please navigate to the link below for your RBR20 firmware version 2.7.4.24:
https://www.netgear.com/support/product/RBR20.aspx#download
For more information on manually updating your RBR20 please navigate to the link below:
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
Best,
Kevin
Community Team
KevinLiT
Aug 17, 2022NETGEAR Moderator
Hello Freddie18,
Best,
Kevin
Community Team
Freddie18
Aug 17, 2022Aspirant
Thanks Kevin.
I did the manual upgrade firmware last night after received the email from Netgear.
After upgrade, it is noticeable that the IP address changes to Vodafone's address range. I guess the old firmware version was kept engaging the former ISP IP address range.
We tried a few online streaming activities in the same time last night and It looks problem resolved.
In case of the problem remains, please allow me to post again.
Thanks a lot.
Love this community group. Give a big LIKE !!
Cheers,
Freddie
- michaelkenwardAug 18, 2022Guru - Experienced User
The clue could be in your first message:
When you change your ISP it is a good idea to reset your hardware to make it forget any settings from the old ISP.
Reset the thing and it forces you to enter the right details for the new ISP.
The firmware update reboots the RBR20 which may have also rebuilt that setting.
