Freddie18
Aug 16, 2022Aspirant
RBR20 system with streaming problem on Vodafone NZ
Dear mates, I newly switched to Vodafone NZ. There is a problem that the streaming of MS Teams, Zoom, Youtube or Nintendo Switch gaming. The streaming will stop, freeze, lost voice channel for abo...
- Aug 17, 2022
Hello Freddie18,
Welcome to the NETGEAR Community!
I understand that you are having network stability issues with your RBR20 on Firmware version 2.7.3.22.
Please manually update your RBR20 to the current Firmware version 2.7.4.24 then check to see if the problem persists.
Please navigate to the link below for your RBR20 firmware version 2.7.4.24:
https://www.netgear.com/support/product/RBR20.aspx#download
For more information on manually updating your RBR20 please navigate to the link below:
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
Best,
Kevin
Community Team
Aug 17, 2022Guru - Experienced User
What modem/gateway do you have from vodafone?
Freddie18
Aug 17, 2022Aspirant
Dear Plemans,
There is standard ONT (https://www.chorus.co.nz/q/model-type-200) and direct connect to the RBR20 with a Cat5 cable.
There is an option to spend a couple hundred bugs to get a router from Vodafone but I choice to direct with ORBI to save more.
Cheers,
Freddie
