momofthecastle
Aug 10, 2019Aspirant
RBR20 trouble
My download speed is cut from 165 to 65 when I move my computer from the main ORBI hardware to upstairs where one of the extenders is. Is this supposed to happen?
Also, the white light does not stay on, but if I push the sync button, it comes on and pulses for about a minute and then goes off. Is this normal?
- momofthecastleAspirant
BTW, we have cable, not satellite.
In terms of the light, yes thats normal.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
In terms of the Orbi speed decrease, many things can change this. How are you doing the speedtest? wired or wireless? Wired is the best way to test speeds as many things influence wireless speeds. Orbi uses a wireless backhaul (unless you wired it in), so it is sensitive to things that impact wireless. This includes foil lined insulation, hvac, wire lathe housing material, wireless interference, etc. Things you can try:
1. move the extender around a bit. it needs a minimum of 30ft from router-satellite. hvac can block signals so moving it can help remove obstruction.
2. enable/disable beamforming
3. enable/disable mu-mimo
4. Try changing wireless channels
