felicem
Aug 20, 2020Aspirant
RBR20 (V2.5.1.16) - connected device does not appear in Attached Devices page
Hello Community, Several connected devices with internet access are not appearing in the "Attached Devices" page. Instead, these devices appear in the "list of allowed devices not currently connect...
Mstrbig
Aug 20, 2020Master
felicem wrote:Hello Community,
Instead, these devices appear in the "list of allowed devices not currently connected to the network" in the "Access Control" page with connection type = Wired !
I've tried turning off access control and rebooting the router, no luck. These devices are all using DHCP and are not in any address reservation list.
Is this a known bug with firmware version 2.5.1.16 ?
Felice
No bug as I run the same firmware. Are the devices wired or wireless? Reboot the system and see if it corrects it.
felicem
Hi Mstrbig,
Thanks for your reply.
Devices are wireless. Reboot did not resolve my issue.
If this isn't a bug I don't know what can be classified as a one ;-).
/Felice
- felicemAug 20, 2020Aspirant
E.g. My niece just connected her macbook to my guest network, it appears in the list of allowed devices not currently connected to the network as a wired device.
This is not a bug ???
- FURRYe38Aug 21, 2020Guru - Experienced User
Are the RBS connected? If so, are they connected via ethernet cable to the RBR?
Has a factory reset and setup from scratch been performed since last update?
felicem wrote:E.g. My niece just connected her macbook to my guest network, it appears in the list of allowed devices not currently connected to the network as a wired device.
- felicemAug 21, 2020Aspirant
Hi FURRYe38,
I have 2x RBS connected wirelessly.
Has a factory reset and setup from scratch been performed since last update?\
No. This will be last resort. I would just like someone from Netgear supprt to acknowledge that this is an obvious bug and possibly try any ohter remedy other than factory reset.
Thanks for taking time to respond.
/Felice
