AP81
Jun 10, 2020Aspirant
RBR20 VPN and torrents
So got this all setup. works exceptionally, except.... When I fire up a VPN service (NordVPN) torrents cease to work at all. Is there any workaround for this? Pretty much a dealbreaker for me.
- Jun 11, 2020
Alrighty... got it working.
1) Changed my IP to manual and set it as 192.168.1.15 (just randomly chose 15).
2) Set up a custom port forward service (Advanced > Port Fowarding/Triggering > Add Service) for my IP with the following settings (I used the ports defined in my bitorrent client).
Service User: Single Address
IP:192.168.1.15
Service Type: TCP
Triggering Port: 11886
Connection Type: TCP/UDP
Starting Port: 11886
Ending Port: 11886The disappointing part was I talked to client services and the expert told me port forwarding would not fix my issue and that there was nothing that can be done. But here we are- some blood, sweat and tears later and I figured it out myself.
On another note, my Roku Express was struggling to connect to Orbi as well (slow and laggy). I created a guest network and it works well now. I figure the Roku box does't like 5Ghz, and is now working well on the dedicated 2.4Ghz guest network.
Hopefully the above helps someone else. I was ready to return it.
CrimpOn
Jun 10, 2020Guru - Experienced User
AP81 wrote:When I fire up a VPN service (NordVPN) torrents cease to work at all. Is there any workaround for this? Pretty much a dealbreaker for me.
This seems like a question to ask NordVPN. Orbi does not support NordVPN "client" software (where every device on the local LAN is routed through NordVPN). So, NordVPN must be running on an individual computer. When software is running on a computer, the Orbi router is entirely unaware of it. It is just "packets in.. packets out." They are all encrypted, so Orbi could not examine them if it wanted to.
Good Luck.
- AP81Jun 10, 2020Aspirant
Yep, it's only running locally on a mac.
Turn off NordVPN and torrents start working. Not sure what the solution is, as a I have a couple of different routers, none of which have this issue. All I can think off is to put the Orbi into AP mode and plug it into my old router.
I'll have a play around, but if I can't get this to work will return the Orbi and get something else.
