AP81's avatar
AP81
RBR20 VPN and torrents
So got this all setup. works exceptionally, except....   When I fire up a VPN service (NordVPN) torrents cease to work at all.  Is there any workaround for this?  Pretty much a dealbreaker for me.
  • AP81's avatar
    AP81
    Jun 11, 2020
    Alrighty... got it working.
    1) Changed my IP to manual and set it as 192.168.1.15 (just randomly chose 15).
    2) Set up a custom port forward service (Advanced > Port Fowarding/Triggering > Add Service) for my IP with the following settings (I used the ports defined in my bitorrent client).
    Service User: Single Address
    IP:192.168.1.15
    Service Type: TCP
    Triggering Port: 11886
    Connection Type: TCP/UDP
    Starting Port: 11886
    Ending Port: 11886
    The disappointing part was I talked to client services and the expert told me port forwarding would not fix my issue and that there was nothing that can be done.  But here we are- some blood, sweat and tears later and I figured it out myself.
    On another note, my Roku Express was struggling to connect to Orbi as well (slow and laggy).  I created a guest network and it works well now.  I figure the Roku box does't like 5Ghz, and is now working well on the dedicated 2.4Ghz guest network.
    Hopefully the above helps someone else.  I was ready to return it.
