blacknatty
May 14, 2019Aspirant
RBR20 wifi doesn't have a valid IP configuration
Running Windows 10, Motorola surfboard sb6121 modem. RBR20 Orbi with 2 satellites.
All was fine this morning until I suddenly lost internet. Got the message "Wi fi doesn't have a valid IP c...
- May 14, 2019
blacknatty wrote:
I note also that the blinking reset light is red, not orange as it was in the video, and it has not stopped flashing after several minutes. If that makes a difference.
Well, blinking red is BAD, BAD, BAD. Here's what Netgear says about the power button LED's:
Router and satellite power button LEDs
Solid green. Your Orbi router and satellite are powered on.
Solid amber. Your Orbi router and satellite are rebooting.
Pulsing amber. You must reset your Orbi router and satellite to factory default settings.
Pulsing red. Your Orbi system might need attention. Contact support.If you are Pulsing red, then the unit is not working correctly. The hardware warranty is 1 year.
blacknatty
Is it such a great idea to do a factory reset after all the work we went through to get it so that Skype and FaceTime would work on my system? Orbi tech support had to manually set up specific ports, as I recall. Wouldn't a factory reset wipe all that?
CrimpOn
May 14, 2019Guru - Experienced User
What happens when the Wiindows tower is plugged directly into one of the LAN ports on the Orbi? (In that case, there is no "WiFi" involved.) If the error message appeared on the Windows machine, do other devices connect over WiFi (phones, tablets, etc.)?
- blacknattyMay 14, 2019Aspirant
I don't think I understand what you mean. If I unplug from the modem LAN to the tower, and instead plug in Orbi LAN to tower, I lose internet again. Is that what you meant?
- CrimpOnMay 14, 2019Guru - Experienced User
Sorry I was not clear. The problem stated was "WiFi doesn't have a valid IP configuration", which implies that the Windows machine is connecting over WiFi. (If it was connecting with an ethernet cable, it would not be using WiFi.) The web link referenced was about how to cure problems reported by Windows. Then, the problem was cured by connecting the computer directly to the modem. i.e. unplugging the Orbi from the modem and plugging in the computer. So, the computer must have an ethernet jack in order to be connected to the modem.
I was suggesting to keep WiFi out of the picture by reconnecting the Orbi to the modem with a cable and then connecting the computer to one of the Orbi LAN ports with a cable. i.e. "no WiFi."
I also asked if the Windows computer is the only device reporting a problem. Do other devices, such as cell phones or tablets appear to be working when the Orbi is plugged in. If you bought an Orbi, you must have things that need WiFi. Do they also report errors?
Thanks for clarifying, obviously I'm not a really advanced user.
My Orbi has only 2 LAN ports - the one marked "Internet" I plug in to the modem. The one marked "Ethernet" I plug in to the Ooma (our internet phone provider). I have no other ports to plug it in to the tower.
So at this time we have no phone service either, except cell phones.
Yes, the other devices that usually work off the wifi now show no internet as well.
