blacknatty
May 14, 2019Aspirant
RBR20 wifi doesn't have a valid IP configuration
Running Windows 10, Motorola surfboard sb6121 modem. RBR20 Orbi with 2 satellites.
All was fine this morning until I suddenly lost internet. Got the message "Wi fi doesn't have a valid IP c...
- May 14, 2019
blacknatty wrote:
I note also that the blinking reset light is red, not orange as it was in the video, and it has not stopped flashing after several minutes. If that makes a difference.
Well, blinking red is BAD, BAD, BAD. Here's what Netgear says about the power button LED's:
Router and satellite power button LEDs
Solid green. Your Orbi router and satellite are powered on.
Solid amber. Your Orbi router and satellite are rebooting.
Pulsing amber. You must reset your Orbi router and satellite to factory default settings.
Pulsing red. Your Orbi system might need attention. Contact support.If you are Pulsing red, then the unit is not working correctly. The hardware warranty is 1 year.
CrimpOn
May 14, 2019Guru - Experienced User
blacknatty
May 15, 2019Aspirant
OK, just had 20 minutes on the phone with support. They fixed it. Not sure how, but got me back up and running. Got everything plugged back in to where it was and wifi has returned. Worked through it on the orbi login websites and made some changes there - had to manually enter in the mac address, for one thing. Everything is now reset back to factory, which is kind of a pain, but it's working. Thanks all for your assistance!
- FURRYe38May 15, 2019Guru - Experienced User
Be sure to do a back up of the RBR config to file for safe keeping. In case you need to do another reset, you can just load the file and save time.
Enjoy. :smileywink:
- blacknattyMay 15, 2019Aspirant
Thanks FURRYe38
- FURRYe38May 16, 2019Guru - Experienced User
:smileywink:
