masan
Mar 30, 2020Tutor
RBR20 wifi signal constantly turns on/off
Hello guys, I bought this RBR20 several months ago and it's been working frawlessly rock solid. But ever since I updated the firmware to the latest V2.3.5.30 yesterday, wifi started to drop const...
- Mar 30, 2020
Anytime you change firmware and are having an issue, a good first step is to factory reset and re-install.
Have you tried this?
If you have and it doesn't help, you can downgrade the firmware to the earlier version. Maybe there's a bug that's impacting your device.
masan
Mar 30, 2020Tutor
Thanks guys for your quick replies!
According to your recommendations, it seems that the factory reset is the way to go.
I will give it a try this evening, after work.
