masan
Mar 30, 2020Tutor
RBR20 wifi signal constantly turns on/off
Hello guys, I bought this RBR20 several months ago and it's been working frawlessly rock solid. But ever since I updated the firmware to the latest V2.3.5.30 yesterday, wifi started to drop const...
- Mar 30, 2020
Anytime you change firmware and are having an issue, a good first step is to factory reset and re-install.
Have you tried this?
If you have and it doesn't help, you can downgrade the firmware to the earlier version. Maybe there's a bug that's impacting your device.
masan
Mar 31, 2020Tutor
After the factory reset, the router seems working fine so far. But I will think twice before running a firmware update in the future if I need to go through the factory reset and configure the router all over again...
I want to choose all of your kind replies as solutions but I can't on this board, so please allow me to pick plemans' reply as the solution since he's the first one suggested the factory reset.
Thanks again for all of you for the kind suggestions.
- FURRYe38Apr 01, 2020Guru - Experienced User
Glad it's working. Save off a backup configuration to file for safe keeping. This helps save time if a reset is needed in the future.
Can use the suggestions at any time for your troubleshooting needs.
Enjoy. :smileywink:
masan wrote:After the factory reset, the router seems working fine so far. But I will think twice before running a firmware update in the future if I need to go through the factory reset and configure the router all over again...
