Road69runners
Jun 05, 2022Aspirant
RbR20 will not factory reset to default
Hi all, i forgot my password to logon to update my router and need to reset it to factory defaults. I press the paper clip in until the power light blinks amber. It blinks like that for a few seconds ...
- Jun 05, 2022
Press the reset button for 15 seconds then release...Does this bring up the setup wizard seen at 192.168.1.1 with a wired PC connected to the back and using a web browser? Be sure to clear out all browser caches.
Jun 05, 2022Guru - Experienced User
Road69runners
Thanks Furrye. That allowed me to reset everything.
- FURRYe38Jun 05, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
