Bchua
Jun 25, 2020Follower
RBR20 with 2 satellites
I am running my Orbi now for at least a month to two months now and I am experiencing disconnecting from internet it will just go offline and I have to wait and it will come online. My firmware versio...
Jun 25, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
