Tom4Net
Nov 19, 2024Tutor
RBR20 with magenta ring but internet
Dear community, I face an issue with my RBR20 router since one week. The system shows suddenly a magenta ring but the internet access is still given. The system consists of an RBR20 in AP mode w...
- Nov 20, 2024
If found the solution.
By changing the IP configuration to DHCP, the magenta ring disappeared. While scanning the network, I cannot determine a double IP.
For DNS, the DHCP server of router issued a different prim. DNS and sec. DNS IP that I have added manually. I just used the IP of the router.
THe effect could be verified: Changing to manual IP again showed the magenta rin, changing to DHCP again solved the issue.
Nov 19, 2024Guru - Experienced User
do you have whatever is managing DHCP (primary router) wired into the wan port on the orbi?
- Tom4NetNov 19, 2024TutorYes, the main router is managing DHCP and is connected to the WAN port of the Orbi. Does it make a difference when the ORBI is in AP mode?
- FURRYe38Nov 19, 2024Guru - Experienced User
Yes, the WAN port is needed for router or AP mode connections for the RBR.
- plemansNov 20, 2024Guru - Experienced User
Is it just the router with the magenta ring, router and satellites, or just the satellites?
Are the satellites connected with a wired or wireless backhaul?
