Tom4Net
Nov 19, 2024Tutor
RBR20 with magenta ring but internet
Dear community, I face an issue with my RBR20 router since one week. The system shows suddenly a magenta ring but the internet access is still given. The system consists of an RBR20 in AP mode w...
- Nov 20, 2024
If found the solution.
By changing the IP configuration to DHCP, the magenta ring disappeared. While scanning the network, I cannot determine a double IP.
For DNS, the DHCP server of router issued a different prim. DNS and sec. DNS IP that I have added manually. I just used the IP of the router.
THe effect could be verified: Changing to manual IP again showed the magenta rin, changing to DHCP again solved the issue.
Tom4Net
Nov 20, 2024Tutor
It is only the RBR20 Router with the magenta ring. The Satelites are not indicating any issue.
The Satelites are connected with the wireless backhaul.
Setup looks like this:
[Router of Provider]-------[NetGear Switch]-----[RBR20]
RBR20 is in AP mode. WAN or LAN port don't show a difference.
Port on PoE Swtich changed but no difference.
The NetGear switch is providing PoE to the RBR20 in connection with a PoE Splitter.
Tom4Net
Nov 20, 2024Tutor
- FURRYe38Nov 21, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
