blacknatty
Feb 03, 2019Aspirant
RBR20 with Skype and Facetime
RBR20 with 2 satellites. Motorola surfboard sb6121 modem. Since I got Orbi, Skype and Facetime don't work. I've tried my Windows based pc (which is wired), my wireless mac laptop, my iPad. People can...
- Mar 10, 2019
Here's an image of what my ports are now. Not sure what I started with and it doesn't list here what is for FaceTime. He worked so quickly that I didn't copy down everything that he changed. Service type is set to port triggering.
He also put me back on daisy chain because of the layout of my house and the stone interior walls. Interestingly, the far satellite currently shows good signal although the closer one shows poor. Both are working fine for my needs though.
ekhalil
Feb 03, 2019Master
Do you know if your ISP supports IPv6? If not then please make sure to disable IPv6 in Orbi. If yes then you need to get the correct IPv6 information (fromyour ISP) in iPv6 settings in Orbi.
- blacknattyFeb 04, 2019Aspirant
Hi Ekhalil,
Thanks for the reply. No, my ISP does not support IPv6. I show it disabled on my Orbi dashboard. Any other ideas?
- ekhalilFeb 04, 2019Master
blacknatty wrote:
Hi Ekhalil,
- Do you use wired or wireless backhaul?
- Do you the same issue if attached to the router as when attached to one of the satellites? Wired as well as wireless?
- Is Daisy Chain enabled or disabled (in advanced wireless settings)? If you're not using daisy chain configuration then please disable it.
- Please make sure that WMM and MU-MIMO are enabled (in advanced wireless settings),
- blacknattyFeb 05, 2019Aspirant
I think I understand your questions, let me know if I get it wrong.
I am using both wired and wireless - the pc and laptop and ipad. (backhaul?) I have the same issues on all devices. I can see and hear the person on the other end, they can see me but not hear me. On all 3 devices, on either Facetime or Skype.
Daisy Chain is enabled, that is my setup with my 2 satellites.
WMM and MU-MIMU are both enabled in advanced settings.
