ektrey
Jul 31, 2018Follower
RBR20 With Spectrum Modem/Router
I’m helping a family member setup internet within their house. It’s approx 5,000 sq ft home with a finished detached garage that needs WiFi. Ideally, I would suggestion the RBK50 (router & satellit...
Jul 31, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
