Jfog86
Apr 08, 2019Aspirant
RBR20 won't connect to internet cm1150v modem
RBR20 won't connect to internet using CM1150V netgear modem. My playstation 4 is connected to the same modem via ethernet and works just fine. I've unplugged and plugged back in the modem and router s...
Apr 08, 2019Guru - Experienced User
Power OFF the ISP Modem along with the RBR for 30 seconds. Power ON the ISP modem and let it sync. Power ON the RBR. Walk thru the setup wizard with a wire connected PC and a web browser at orbilogin.com.
Be sure to use a good working LAN cable between the modem and RBR. CAT6 is recommended.
