tanush14
Sep 03, 2019Aspirant
RBR20
Smart TV does not work on wi-fi. cable only. Why:?
Sep 03, 2019Guru - Experienced User
A little more info is needed.
What smart tv are you using? (brand and model number)
Postive it has wifi? I know it sounds stupid but we've had people ask about it with tv's that don't have built in wifi so I have to ask.
Are you able to see any networks if you do a wireless scan?
What error are you getting?
Firmware on RBR20?
How far from the router/satellite are you?
You can try enabling/disabling these features to see if it helps: beamforming, mu-mimo, daisy chaining
- tanush14Sep 03, 2019Aspirant
tv lg oled. smart. From applications only you tube and netflix work. Other applications do not work on wi-fi. When I connect the cable to the modem, then everything works.
- plemansSep 04, 2019Guru - Experienced UserSo some applications are working so it's connecting, maybe not with enough bandwidth. What errors do you get? And can you answer the prior questions and try the potential fixes I gave you? And saying lg oled TV isn't a model. It's like saying netgear ac router. There's many models it could be.
- tanush14Sep 04, 2019Aspirant
LG OLED65C8Y 4K 65 модель телевизора. Вай фай встроенный есть. Работает нетфликс и you tube
