tanush14
Sep 03, 2019Aspirant
RBR20
Smart TV does not work on wi-fi. cable only. Why:?
tanush14
tv lg oled. smart. From applications only you tube and netflix work. Other applications do not work on wi-fi. When I connect the cable to the modem, then everything works.
Sep 04, 2019Guru - Experienced User
So some applications are working so it's connecting, maybe not with enough bandwidth. What errors do you get? And can you answer the prior questions and try the potential fixes I gave you? And saying lg oled TV isn't a model. It's like saying netgear ac router. There's many models it could be.
- tanush14Sep 04, 2019Aspirant
LG OLED65C8Y 4K 65 модель телевизора. Вай фай встроенный есть. Работает нетфликс и you tube
LG OLED65C8Y 4K 65 TV model. Wifi is built-in. Netflix works and you tube
- plemansSep 04, 2019Guru - Experienced User
Netflix and youtube have the ability to dynamically adjust resolution and bandwidth based upon how much is available. Not sure about other apps.
What speeds do you pay for?
Are you connected to the 5ghz signal?
Can you speed test with your tv?
Also, what size is your house?
How many satellites are you running?
Firmware on them?
are they using the wireless backhaul or wired?
Have you tried doing a wireless scan to see if you're on the optimal wireless channel?
