Peanutbuttercup
Jan 25, 2020Follower
RBR20
We’ve plugged in the router but have no internet - the wifi shows up but will not display internet
1 Reply
Will need more information here:
Is the Orbi system operating in Router or AP mode?Modems with built in routers:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
