Tjharris6's avatar
Mar 05, 2020
Rbr20
Constant disconnects from the iPad switching to cellular.  I, m pretty experienced with routers but I,m confused. I get multiple random disconnects between the orbi and my iPads and I have no reason why. I, running 13.3.1 on the iPads and stock orbi firmware. Any ideas would be helpful.
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
  • Retired_Member's avatar
    Retired_Member
    Has your network ever worked properly?  When did these disconnects begin.  What if any changes do you do to your network?
    Always nice to provide more historical info.
    Most of the answers to Message 2 of 3 would have surfaced during the initial install.
