Napp
Jul 04, 2020Follower
RBR20
I’m using optimum Arris for a cable modem. I purchased the orbi system with one satellite. Upon installation and for 2 months after I had great speeds. Tested between 350-400mbps consistently. Lately ...
Jul 04, 2020Guru - Experienced User
I
